Fuel Pump
Old Apr 28, 2008 | 12:45 PM
rtransom's Avatar
Default Fuel Pump
I think my fuel pump may be dead on my ’03 CBR600F4i and I was wondering if anyone has had issues with theirs. I went to turn my bike on and it didn’t make the noise it usually does when you first turn the bike on. So I checked the kill switch, all the connections, and the fuses. All was good. So if anyone has had any issues like this can you please help out.
Old Apr 28, 2008 | 01:52 PM
2kgixx's Avatar
Default RE: Fuel Pump
check if the bikes in gear
have u crashed recently, if so unplug the tipover sensor and plug it back
Old Apr 29, 2008 | 11:58 PM
Fort Collins's Avatar
I had the same problem. check your tip sensor fuse. if thats on. unbold your tip sensor (under your wind screen) and take it off and just give it a good shake. then put it back on. or you might also want to unplug it and over ride it real quick. (no over riding it will blow your fuse) but then just plug it back in and replace the fuse. I did both of those things and mine has worked fine ever since. but you could have a bad fuel pump too...never know. hope that helps.
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
