Fuel overflow question
Old Apr 1, 2010 | 03:59 PM
speedyf4i's Avatar
Yea its the overflow thats leaking, and i plugged it off last sunday. i figured it would have been a crack in the hose. i dont ride in the rain anyway, so not worried about that...thanks for the clarification...its much appreciated
Old Apr 1, 2010 | 05:06 PM
Xuracing's Avatar
IIRC i thought that was also the breather?
capping something that was there to start with doesnt sound like a good idea
Not sure if you watch mythbusters but they capped off a port on a water heater and it exploaded like a bomb and took out a house, went through all 3 floors through the roof of 3 stories...
yeah i would be cautious especially if its just a hose, replace it!
Old Apr 1, 2010 | 05:36 PM
james_hale2's Avatar
no its a metal tube that runs the inside of the tank. the rubber hose just connects to the bottom and runs down the farring. the one he is blocking is only there to drain what comes over the tank opening or water from rain or washing. the other is the vent. its opening is inside the tank not under the cap. but here ya go easy test open the gas cap and blow through the tubes. one will blow air through the hole outside the cap under the ring, the other will hiss inside the tank and also runs to another fitting on the bike under the tank i belive. hell now im getting confused. lol but anyway like i said plug it keep it dry and save 200-800 bucks. use some gas treatment every once in a while lol
Old Apr 1, 2010 | 05:55 PM
Xuracing's Avatar
well! hope everything turns out well!
Old Apr 2, 2010 | 10:42 AM
speedyf4i's Avatar
so far so good, went for an hour long ride and all went well
Old Apr 2, 2010 | 02:01 PM
jonld's Avatar
If it were mine, I would pull the tank off. Remove the fuel pump to get access to the pipe and see what kind of damage your really looking at. Then weld it up if possible or cut out the bad section of tubing and use some rubber fuel hose like they do on the pump. The way your doing works but It keeps it from working like designed.
Old Apr 7, 2019 | 04:40 PM
Steve White's Avatar
How do you unclog the over flow tube inside the tank for rain Draining
d4v
Jun 24, 2013 02:58 PM
93MitsuVR4
Jul 20, 2011 08:34 PM
rockstar_22
Sep 16, 2010 05:36 PM
rockstar_22
Apr 11, 2010 12:24 AM
shraz
Nov 17, 2008 01:25 AM
