2002 cbr 600 f4i REAR CALIPER MOVES WHEN BRAKES ARE PRESSED.
Old Feb 18, 2019 | 05:34 PM
Zac May's Avatar
Default 2002 cbr 600 f4i REAR CALIPER MOVES WHEN BRAKES ARE PRESSED.
i don’t understand what is supposed to hold my caliper back from moving, I’m lost.
Old Feb 18, 2019 | 06:02 PM
boredandstroked's Avatar
Caliper attaches to bracket. Bracket slots into swingarm. Pretty simple.
Old Feb 18, 2019 | 06:03 PM
ceebeeaarguy's Avatar
Hey, what exactly is moving? The entire caliper? Remember there'd be some very slight jerking movement as the back brake as it doesn't work like front which should have zero movement....THe rear caliper is floating type whereas the front is fixed. But if you can grab the rear caliper and it moves, then your mounting screws are lose. Tighten them up to specified torque values
Old Feb 18, 2019 | 06:19 PM
Zac May's Avatar
🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️ I’m an idiot.
Old Feb 18, 2019 | 06:51 PM
wes 17's Avatar
Never mind Zac.......it happens to all of us once in while ! .........one of them “how the .... does that go back ? You were just unfortunate to post it first lol.
Best of luck mate.
Old Feb 19, 2019 | 03:24 AM
Zac May's Avatar
Best of luck mate.
thanks man
Old Feb 19, 2019 | 05:41 PM
Doc Samson's Avatar
Dude, we've all been there! Some of us (I'm looking in the mirror) more than others! I usually allot 2-3 times above what everyone else on the forums say a job will take re: time and effort. But when you get it figured out and everything comes together? Priceless...
Old Feb 21, 2019 | 06:11 PM
ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahhahahahahahahahahaha
Old Feb 21, 2019 | 06:12 PM
But to be fair, its only funny cause we've all done something like it before.
Old Feb 21, 2019 | 11:08 PM
Webby64's Avatar
Without looking at your f4i caliper, that rear caliper design is a good one, & it looks to me that the break pads are not in their correct position giving very poor break performance & the feeling that the calipers are moving about, In short get the rear break pads pulled & correctly fit them, & unless the previous incorrect fitted break pads haven't damaged the calipers & it's mounts, you shouldn't have any dramas
