Fuel line problems
Old Nov 12, 2017 | 08:15 AM
Johnnyr1red's Avatar
Default Fuel line problems
Took my bike out for a a first proper ride after rebuilding it and it won't rev over around 6000 revs. It's fine around town, rides perfectly and is responsive but on a faster road when you try to open it up it bogs down as it it isn't getting enough fuel.
I've had the tank off for painting and I think the main fuel pipe may be the problem. I thought I had put it back as it says in the manual but the pipe has a 180 degree bend on itself flattens where is bends.
If you are familiar with your fuel system, can you yo look at my pic and tell me if it looks like it should.
Thanks
Old Nov 12, 2017 | 10:22 AM
Gunk's Avatar
As I said in your other thread, it shouldn’t collapse like that, that looks as if it’s not a genuine Honda fuel pipe. I’ve just ordered one for my F3 (it was split) from David Silver about £13 delivered
Old Nov 13, 2017 | 04:46 AM
The F3 and the F4i have different fuel delivery systems don't they, mine has a banjo bolt fitting as the main fuel pipe, this is the one that I think is causing me the issues.
Old Nov 16, 2017 | 05:54 PM
boredandstroked's Avatar
Its backwards. They told you that in the other thread.
Old Nov 16, 2017 | 05:55 PM
Old Nov 17, 2017 | 06:37 PM
ceebeeaarguy's Avatar
I am pretty sure you already have checked this, but the tank breather hose sometimes can have a kink etc. I don't really think that bend would cause you such obvious problems.
Since you said you rebuilt the bike, probably worth going through the air/vaccum lines which you may have played with(lets say for throttle body sync) once more. Does it idle fine or needs throttle on cold mornings?
reefatx
Apr 24, 2023 09:53 PM
FRANKTHETANK
Oct 18, 2006 11:38 AM
nkx
Apr 5, 2006 03:48 PM
petermandaniel
Dec 13, 2005 06:02 PM
bubba_d_duck
Dec 11, 2005 09:26 PM
