fuel petcock vacum line?
Old Apr 10, 2006 | 10:13 PM
FRANKTHETANK's Avatar
Default fuel petcock vacum line?
where does the vac line come from or go to from the fuel petcock, i just got this 92 f2 and i cant find a vac line. do i need one? fuel come out of the petcock pretty good with out it. thanks
Old Apr 10, 2006 | 11:54 PM
Nick I.'s Avatar
Default RE: fuel petcock vacum line?
if i am not mistaken just hangs down underneath the tank... make sure it doesn't get pinched under the tank.. it happened to me and the bike would stall every 5 minutes.
Old Apr 11, 2006 | 12:09 AM
there is no hose hanging anywhere near the tank or carbs. do i need the vacume. where should i splice into if i need it?
Old Apr 11, 2006 | 12:23 AM
Nick I.'s Avatar
take a look at these diagrams, its the best i can do at the moment, the first picture is the tank, the second describes which hoses are which.
Old Apr 11, 2006 | 12:36 AM
city worker's Avatar
I have 93 f-2 and I have 1vac line back side of petcock can only see from right side of bike looking thru to the back of pet cockvac line and 2 smog lines that connect to the bottom of tank and run to a canister under the seat (I have cali model )
Old Apr 11, 2006 | 12:41 AM
#5 is it, I was lookin in my manuel but could not find a pic like that ,nice diagram nick I
Old Apr 11, 2006 | 10:21 PM
thanks guys. ill look around again to marrow and try to find it.
Old Oct 18, 2006 | 02:48 AM
Ar15 guy's Avatar
Anyway we can revive those diagrams? I need them badly. I think my petcock may be bad. Mine will not leak gas at all...it did run before it was apart tho.
Old Oct 18, 2006 | 11:38 AM
Krokus_92F2's Avatar
I think there needs to be engine vacuum to draw fuel through the petcock as I remember.
That way fuel does not run to the carbs when the engine is not running. I remove my tank all the time and fuel never leaks from the petcock even when left in the on postition.
Elimax
Jul 29, 2013 06:17 AM
robrea19
Jul 20, 2012 08:56 AM
graygeezer
Jun 17, 2011 07:39 AM
chicosince1979
F2 Tech
Sep 10, 2010 08:30 PM
