fuel injection problem...?
Old Sep 5, 2007 | 10:38 AM
slimbb4's Avatar
Default fuel injection problem...?
alright, i have an 01' f4i. the problem is that every once in a while it will start "sputtering" (hopping/jerking around) as if it were misfiring. i replaced the spark plugs yesterday and the problem persists.
occassionally it will do it so bad that it back fires and my bike stalls. when it starts to jerk a little bit the FI (fuel injection) light comes on. it will go off and on while riding until the bike stalls, back fires, or it will suddenly just stop and the bike rides perfect again.
i thought the new plugs would fix the problem but i guess not. the only other thing that i could think of is it could be the injectors or the fuel pump?
any suggestions?
any help is appreciated. thanks in advance.
_zac
Old Sep 5, 2007 | 11:06 AM
EHonda's Avatar
Default RE: fuel injection problem...?
Slim, have you checked your battery connections? I had a similar sputtering issue when I was giving it constant throttle. Tightening the connections solved that problem right away. Hopefully it's something that easy.
Old Sep 5, 2007 | 11:36 AM
slimbb4's Avatar
thanks alot man... i will try it today. i think i might actually go get a new battery anyways because my bike was sitting for 2 months while i did body work and paint. i will try it and post the results.
any other suggestions are appreciated.
thanks
_zac
Old Sep 7, 2007 | 11:45 PM
slimbb4's Avatar
Ehonda... YOU ARE THE ***** TRUCKIN' MAN!!!WOOHOOO.. lol
aside from that.... tightening my battery cables fixed her right up and shes running perfect again
thanks alot man
_zac
yithway
Jun 24, 2009 07:25 AM
soccercojo4
Mar 15, 2008 11:29 PM
9two9
Jan 26, 2008 03:42 PM
slimgottabike369
Jun 11, 2007 06:45 PM
Blk01f4i
May 4, 2007 04:22 PM
