frustrating problem with my f4i
Old May 3, 2009 | 06:42 PM
ragon1981's Avatar
Default frustrating problem with my f4i
ok guys im new to the forum, and have some problems with the bike i can not figure out.
i have 2001 cbr f4i and i took it out for its first ride yesterday and every time i come to a stop the bike wants to die. the idle is crazy, it will cruise great when i rap thru the gears but as soon as i stop will die if not given throttle.
i bought a used fuel pump recently on ebay and it seems fine, changed the spark plugs that were toast. after reading some threads on here i thought maybe it was the FPR but i took off the vaccum hose to it and don't see any fuel spurting out so now i am at a loss! any help you guys have would be great thanks.
also i have a venting problem with my fuel tank and im not sure why!
Old May 3, 2009 | 07:22 PM
RBarker63's Avatar
i have the same bike and had the same problem. my RPMs were too low so i cranked them up to 1400rpm idle, and havnt had the problem since.
Old May 3, 2009 | 07:23 PM
cageless's Avatar
i tried the vacuum thing like you also and thought i could rule out the FPR but it ended up being the problem.
Old May 3, 2009 | 10:55 PM
Aken's Avatar
July 2008 ROTM
Have you tried adjusting the idle ****...?
Old May 3, 2009 | 11:01 PM
Zero1080's Avatar
^ What they said. Higher idle speed. As far as the tank leak goes, I'd take the tank off, check all the seals and ports, and make sure everything is 100%. Then if you don't find anything wrong, take it in.
Old May 3, 2009 | 11:48 PM
andymp3's Avatar
Mine started acting up last week...It would spit and sputter and only seemed to work good when I cranked on her....I took everything appart, removed my power commander and it was still doing it....As a last resort I took the fuel tank off and drained it thouroughly and that was the problem...I put fresh fuel in and it has never worked better....Make sure you ground wires are ok and make sure you have not ended up with bad gas...I gassed up and ended up with water in my gas....I wish i would have tried it first however I am glad that is all it was....Any chance you have the same issue? Bad gas can do all sorts of weird things....
Old May 4, 2009 | 12:28 AM
ragon1981's Avatar
I've tried adjusting the idle **** and it still wants to die at stop signs. I drained the tank and put fresh gas in it yesterday. I talked to a buddy of mine and he said the tank vents at the gas cap and that i should buy a new cap and that should take care of the venting problem, does the tank vent at the gas cap??
Old May 4, 2009 | 09:34 AM
skoobydoobie's Avatar
The tank vents outta the hose coming outta the bottom of the tank. Make sure they ain't pinched. Try running some seafoam through it, maybe your injectors are dirty.
Old May 4, 2009 | 03:42 PM
ragon1981's Avatar
Ok i got a new FPR ordered, where can i pick up seafoam at? is it a pretty regular item at a bike store??
jimmyjames
Feb 26, 2014 05:37 PM
R Dub
Jul 16, 2010 10:47 PM
iceman423
Jan 5, 2010 09:36 AM
hopz
Jun 10, 2009 08:12 PM
dwschultzy
May 9, 2008 10:38 PM
