front sprocket?
Old May 24, 2007 | 11:15 AM
f4iguy8804's Avatar
Default front sprocket?
Has anyone used the RK 520 conversion with quick accelleration? I'm asking because I just installed and it seems that the front sprocket has a little bit of play even with the bolt tightened. Everything is tight and there wasn't a washer or spacer on the original. When I took it on a test ride, everything feels great and actually feels like a new bike. Overall I am happy with the change in gearing but just wondering if I should be concerned with the play.
Old May 24, 2007 | 08:44 PM
Stephens's Avatar
Default RE: front sprocket?
I believe there has to be a little play in it. I had the same with mine, and no problems.
Old May 24, 2007 | 09:29 PM
kup125's Avatar
its normal
Old May 25, 2007 | 12:37 AM
bwf4i's Avatar
+1
Old May 25, 2007 | 09:59 PM
drprcbr's Avatar
did you say that when you took off the original sprocket there wasnt a washer? cause if i remember correctly, i believe there is suppose to be a spacer/washer between the sprocket bolt and the sprocket. pretty sure about it, but not 100%...
Old May 25, 2007 | 10:41 PM
Tahoe SC's Avatar
some bikes have the washer, others don't. not to make matters worse, but i don't remember ever having the gap though...
Old May 26, 2007 | 02:19 AM
f4iguy8804's Avatar
I checked with the locals and they tell me that this is normal. Thanks for your input.
slightreturn
Apr 19, 2013 10:25 PM
aeroworks
Mar 16, 2006 11:57 AM
