Front End Problem
Old Jun 6, 2007 | 01:04 AM
Gdub's Avatar
Default Front End Problem
Hey Guys, I'm havinga problem getting my front fender on. I changed the forks because they were slightly bent. The forks are even at the top (@ the handlebars), but the holes don't line up for the fender (one is too low). Do you think it could be a bent axle or maybe bent steering stem or triple clamp causing the height difference? What's the best way to check these things?
Thanks for any advice/insight!
Old Jun 6, 2007 | 01:30 AM
therabbit's Avatar
Default RE: Front End Problem
You might have ended up with one F4 fork and one F4i fork, they are identical except for the fender mounting points.
Old Jun 6, 2007 | 10:33 AM
slip_'s Avatar
It doesn't sound like it could be a bent axle. Especially if you removed the axle and put it back in alright.
ashylarry
Oct 6, 2011 06:07 PM
b.rinner
May 21, 2011 01:20 PM
CSD10
Aug 18, 2009 09:54 PM
icreepin
Jun 12, 2008 03:49 PM
Pablo
Oct 5, 2006 03:33 PM
