Flashing Engine Oil indicator
Old May 7, 2011 | 06:35 PM
f4iven's Avatar
Question Flashing Engine Oil indicator
Hi,
I have a 2001 F4i and last week I changed oil on it (This wasn't first time). Since then, the Engine Oil (Low pressure?) is flashing after I turn on the ignition key. But, it goes off as soon I start the engine. This is the first time I am seeing this issue. As per the book, I checked the engine oil level and everything looks right. On a level surface, after idling the engine for 2-3 minutes and turning it off for 2-3 minutes, the oil level is just below the "upper mark". I put about 4Q oil in it. Other than this issue, it runs fine and the power is also seems good.
I am confused and dont have anything else to try. Should I take off some oil from it? Please advice,
thanks for your time,
letsride
May 27, 2013 04:57 PM
f4iven
Jun 12, 2011 08:55 PM
f4iven
May 10, 2011 10:45 AM
Hindra
Mar 21, 2007 09:38 PM
z300x
Feb 9, 2005 06:49 PM
