Flame, popping and gas smell
#22
UPDATE
I got my new fuel pressure regulator in yesterday. Install was easy. Got it done just in time to go to work. So i was only able to put 15 miles on the bike yesterday but the fuel smell, flames and popping have gone away. The bike also idles smooth and has a little better throttle response.
Big thanks to all of you that helped cause this is the best my bikes ran.
Heartland Honda was a great place to order OEM parts from. Quick delivery and great prices.
#23
UPDATE:
I just got back from a 150 mile hard ride. The fuel smell is gone. The popping and back fire are back. If I left off higher than 6,000 rpm the backfire, popping sound happens. So far no blue flame.
I had 2 small exhaust leaks. The first one was at the midpipe to header and the second one was at the midpipe to exhaust can. I bought some exhaust leak stuff and fixed the midpipe to can. I have not fixed the midpipe to the header.
I will fix the midpipe to header today. But the weather is going to be bad for the next 5 days. So I was hoping you guys might have some other ideas since I cant ride and have time check things.
Quick recap. I have replaced plugs, filter, Fuel Pressure Regulator, remapped PC3 and checked all hoses to make sure I have no loose ones, and repaired a small exhaust leak.
Thanks in advance for help
#24
#25
#28
