FI Light?
FI Light?
Sigh*
So when my bike gets warmed up and maybe after a minute or two of riding that stupid FI light glows red
and my speedo starts getting all kinda of crazy number for a few seconds ad then drops to zero. I
dont feel any difference in the bike its still smooth all around . I dont get it . From what i believe
the FI light is the equivalent of hondas Check Engine light. Any advice? get a scan tool maybe?
disconnect the battery? i am more of a do it yourself kinda of person , so i wont take it to a dealer
or shop unless seriously necessary. Thanks in advance
RE: FI Light?
I had the same problem start today! Very odd. Not sure what is going on, but the FI light comes on after a minute. Had to ride home about 5 miles like that, seemed to run fine. When I let it idle it usually goes off, or flickers on and off.
The only local Honda dealer(where I bought it in August), has no appointments available until the first week of May! Friggan ridiculous...
RE: FI Light?
Well, I fixed mine. The problem was that I bumped a dip switch on my Speedo-Healer and switch #5 was stuck halfway between off and on and that was causing the FI light to come on. I reset it and put all switches down and then went out ripping up some back roads and no more FI light.
RE: FI Light?
ORIGINAL: SquireSCA
thats exactly what happens to me. Except i dont have a speedo healer
RE: FI Light?
I was looking at a F4I to buy that had a FI light blinking and I posted about it and I belive Icefox was the one that helped me
If you don't know how to pull the code on this bike... turn the ignition off and remove the front seat and short the service check connector with a jumper wire. Turn the ignition on and the engine kill switch to run. Count the blinks of the FI light and if you don't have the definitions of the code, just post how many times it was blinking and I can look it up for you if you like.
Hope this helps you Good luck all
my FI light is on and there is a red light i think its the mil light and bike is running great HELP!
cubanjoe
12-27-2007 09:00 AM
