Factory Pro Shift Star Evo Kit
Old Sep 29, 2013 | 09:21 PM
YunMing's Avatar
Default Factory Pro Shift Star Evo Kit
So after installing this I have had some issues with cct rattle. I'm not sure if I was supposed to loosen the cct before removing the clutch basket and reinstalling.
Old Sep 29, 2013 | 09:47 PM
CJardine's Avatar
Track junkie & modaholic
I did not touch my CCT when I put mine in, you have a manual one right? I would just readjust it and put some silicone glue on it to keep it from moving.
Old Oct 1, 2013 | 02:25 AM
YunMing's Avatar
Only thing I had trouble with when installing the FP shift star was removing the basket with the scissor gears. Eventually I removed the basket with a bit of force and when I put it in I lined up them again. I have been adjusting my cct the same way I did it the first time but no luck. I still get rattle at 5k+ rpm
Old Oct 1, 2013 | 04:08 AM
CJardine's Avatar
Yea it took me a bit to realise the proper way to put the basket back in. I had to walk away for 15 minutes I reread the steps a good 3 times before it clicked. Did you check that you installed everything correctly and that all the pieces were put in? Even IF your cam chain was stretched a bit by the install, your adjuster should be able to compensate. Sometimes you just need to take everything out and reinstall it, not sure if you already did that. Have you emailed mark at Factory Pro about it? He is super helpful.
Old Oct 1, 2013 | 11:03 PM
YunMing's Avatar
I haven't emailed him about it. I think i'm just going to recheck my work tomorrow. Should only take a few hours.
Curvattacka
Nov 6, 2013 09:16 AM
YunMing
Jul 30, 2013 08:39 PM
super60daytona
F2 For Sale / Trade / Wanted
Jul 10, 2011 08:49 PM
REDrum
Aug 20, 2009 12:40 AM
