F4i starting problems
Old Jun 10, 2009 | 04:22 PM
DBEAU's Avatar
Default F4i starting problems
Hey everybody, I need some help.
As you many know I wrecked my F4i last rear and am so very close to getting it fully back together.
Everything is there minus the plastics. So here is whats going on...
It will turn over, But it won't start. here are the things i've noticed..
Fuel pump won't prime (the obvious problem)
All fuses are good
Left turn signal indicator is solid
Headlights don't come on at all.
The reason I give you this info is because I thought I read somewhere about the headlights not coming on being a sign.
Also, I don't know what the left turn signal indicator being solid may signify.
Any help/ideas would be appreciated.
Old Jun 10, 2009 | 04:29 PM
Elfling's Avatar
Ladies Lounge Moderator
fuses/relay?
Pretty much identical symptoms here:
http://www.fireblades.org/forums/hon...uel-issue.html
Old Jun 10, 2009 | 05:10 PM
FLYOU's Avatar
front fairing isn't connected properly sounds like.
fuel pump won't prime = no signal from bank angle sensor.
i had the same problem.
Old Jun 10, 2009 | 05:24 PM
DBEAU's Avatar
All the connections seem fine. I pulled them all apart and there are no bent pins or anything.
Old Jun 10, 2009 | 05:35 PM
FLYOU's Avatar
yeah my connection was solid too and it still didn't work. had to clean up the grounding pin (green wire) and dielectic grease the **** out of it in order to get it working again. worked like a champ after i did that. 1 year later and the problem never came back.
If it's solid, then it'll probably be a bank angle sensor issue. if the bike is on it's side, the bank angle sensor will trip and not allow the fuel pump to prime. safety feature. this is not true of the clutch or the kickstand sensor.
however...
The bank angle sensor has nothing to do with the turn singnal and everything to do with the harness. When 2 things are wrong, then they're probably related. Gotta keep that in mind.
Old Jun 10, 2009 | 05:56 PM
DBEAU's Avatar
so you're saying the turn signal light is directly related to a possible loose connection?
Old Jun 10, 2009 | 06:29 PM
FLYOU's Avatar
yep. Look at my 1st pic. All of the lights are on. turn signals were both activated but the headlights wouldn't work.
If only 1 turn signal is activated, you might be getting a partial connection...
Old Jun 10, 2009 | 06:42 PM
DBEAU's Avatar
I just discovered a few things...
When I turn on the ignition I blow the headlight fuse..
When I use the turn signal selector, I blow the bank angle sensor/ starter fuse...
Old Jun 10, 2009 | 07:05 PM
FLYOU's Avatar
oh well that changes things up a bit lol. thought the fuses were all good.
Well, start around the front harness area and check the wiring for any frays or burning along the way. headlights, turn signals, everything. exposed wire grounding could be arcing. i would disconnect every electrical connection in the front fairing and check for any corrosion or anything out of the ordinary.
most of them you can check without taking off the front fairing.
electrical problems are usually bitch to find, but a cinch to fix.
edit: double check those relay's too.
Old Jun 10, 2009 | 07:24 PM
DBEAU's Avatar
I know, I hate electrical... But where would we be without it lol.
Actually, let me rephrase that... I love electrical, I just hate diagnosing it.
