F4i Running Rough
Old Apr 5, 2010 | 05:17 PM
573v3's Avatar
Default F4i Running Rough
My bike was riding well after storage, but now the FI light comes on occasionally after really poor throttle response. It usually happens when I maintain an RPM, like staying at 4000 instead of climbing or falling. After the FI light comes on it usually dies on me. I just ran some sea foam through the engine, and it seems to have helped a bit, but I'm wondering if theres anything else I can work on before going to the shop. Thanks!
Old Apr 5, 2010 | 10:11 PM
vangill's Avatar
July 2010 ROTM
that sounds odd. try going thru some fresh gas, and do all the maint on your bike first. like plugs, clean/change air filter, oil change(unless youve done this already)
if the light comes on and goes away and act like it never happens the bike prolly just needs to be cleaned up-please forgive me, i cant think of a better way to say it. im not trying to say u have a dirty bike. you might also have a loose connection on your map or something. try jumping the diagnostic port to get the codes and see what the ecu says is wrong
Old Apr 5, 2010 | 11:04 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
There's quite a few things that could be afoul. The Service Manual has a real good troubleshooting section, you can download it from here (link). Check out Section 5, particularly the self-diagnosis procedure.
Old Apr 6, 2010 | 04:39 AM
DonnyBrago's Avatar
Post up the fault code
Old Apr 7, 2010 | 10:25 PM
F4iMiller's Avatar
i had the same problem, my bucked really bad for no reason. it ended up being that i didnt screw the battery screws back in all the way, one was crooked and the connection was bad. Check your battery hook ups!
Old Apr 7, 2010 | 10:32 PM
573v3's Avatar
Im going to figure out how to check the fault code. My mechanic told me it could be the battery- I lost a screw from when I put it into storage and used a different sized one. I'll try to get a better one from home depot tomorrow, otherwise its the mechanic.
Old Apr 13, 2010 | 11:37 PM
573v3's Avatar
Default Thanks
So, I checked the battery; the Red plastic (I think indicates - for the wire) had a small burn mark on the side. The screw I used was gold and wayy different from the original, somehow found the original near the battery, swapped it out, now she rides like a dream. THANK YOU for the advice, saved me from paying a mechanic to do the same damn thing!
Old Apr 14, 2010 | 01:06 PM
speedyf4i's Avatar
Wouldnt the red insulator be for the positive connection?
Old Apr 14, 2010 | 07:14 PM
Incognito's Avatar
Question Wouldnt the red insulator be for the positive connection?
Yes, it would be.
Old Apr 15, 2010 | 01:38 PM
573v3's Avatar
I stand corrected.
12stones
May 20, 2019 03:37 PM
victoruk2
Dec 8, 2014 09:02 PM
Tort93f2
Apr 13, 2012 12:18 PM
ruckus724
Aug 18, 2009 10:23 AM
eddie v twin
May 1, 2006 12:09 PM
