F4i problem please help
Old May 20, 2012 | 08:50 AM
ricky_boss's Avatar
New Member
Default F4i problem please help
hiii i just baught a 2002 f4i 8000 km ... the problem is that i give some gas it will rev up normal to 6000rpm and then it wont go up any more ... in any gears ... more gas i give the less fast i will go around 6000 rpm ... under the bike goes like a charm ... starts perfect idlle perfect ... no smoke in the back ... wen i baught the bike i had to change the fuel regulator and gas pump ... pleasse help im new in to this
Old May 26, 2012 | 04:53 PM
A-stat's Avatar
Maybe yur butterfly's are stuck check yur throttle body for sure
Old May 26, 2012 | 08:38 PM
RudyGT's Avatar
is there a chance the bike has some silly rev limiter on it because its restricted from Europe where they do that sort of thing?
Old May 27, 2012 | 09:30 AM
squidhead's Avatar
After you check the other things, I know it sounds stupid but check the fuel filter. I have had 2 situations where the filter was clogged to the point it will flow but only to a certain point (volume) of fuel. One time on my car the other on my boat, usually when you hit that point it will start to buck or bog down. I know it is a bike but it is still possible. I also had a boat (4 cylinder) with a bad coil. It was only running on 3 cylinders. Started an ran PERFECT but would only get to 1700 rpm,s thats it. Drove me nuts for 3 weeks!!!!!!! You would never imagine a motor could run perfect, start perfect, on 3 of 4 cylinders, after checking for spark found out a coil pack was bad, changed it out and it ran 100%, good luck
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
