F4i overheating issue
Old Sep 2, 2013 | 04:43 PM
davedude44's Avatar
Default F4i overheating issue
Okay I have read up quite a bit on this but wanted to get some additional input. 01 F4i has 16k on it. On the highway it usually stays around 180. When in heavier traffic can creep upwards of 200. Now when i come to a stop light the temp rises extremely fast. Much faster than it has in the past. One stop light will put me at 210 and if i hit another one will be upwards of 230 and will continue to rise. The fan does kick in. The coolant is full. Besides having a faulty thermostat with it being stuck closed is there anything else this could be? Not sure if water pumps go bad on these things that often. The frame also gets very hot to touch and can often feel heat radiating from the motor.
Thanks
Old Sep 2, 2013 | 06:45 PM
R Dub's Avatar
October 2011 ROTM
230 is a bit warm. The water pumps do go out. I had to replace mine but when they normally when they go out the leak coolant through the weep hole and then your coolant is low and doesn't touch the switch. This doesn't sound like your problem, sounds like you have bad thermostat. I would start there.
Old Sep 3, 2013 | 11:43 AM
davedude44's Avatar
Yeah it will continue to get warm upwards of 250 before i end up shutting it down. My gut leads me to the thermostat but I am trying to pretend its not because of all the fun involved replacing it
Old Sep 3, 2013 | 02:03 PM
svek's Avatar
You say that the fan comes on so it could be that your rad is plugged (internally), therm stuck closed, WP not pumping enough or at all.
I'd start with checking the thermostat. Put it in a pot and boil some water, see if it opens
Old Sep 18, 2013 | 08:23 PM
solololos's Avatar
Registered Users
I just had an overheating issue too. Sounds like it could be the thermostat, i replaced mine (even tho that wasnt the issue) Its an easy job changing out the thermostat
darryle
Feb 21, 2010 12:37 AM
StangLou
Sep 1, 2007 08:49 AM
cbr_sinner
Jun 1, 2007 12:44 AM
TennesseeCBRF2
Aug 27, 2006 03:26 AM
VoX
Aug 20, 2006 04:30 PM
