f4i is killing me!!!!
guys i posted a while back about a missing f4i, well i put new coils on it and reg/rec on it, and its still runnning like crap. now with that said, this is my first bike and i dont know much so dont laugh if this is a stupid question. but i pulled the stator cover off just to see how it looked in there, and about a half a quart of oil came out. is this normal for oil to be in the stator? i am beginning to think that this is what is causing the whole problem.
man it wont even run now. it was missing like hell, but now it wont even run. my guy just called me and told me to check the rollover kill switch, thats about the only thing left to check and replace other than the ecu.
anyone have a wiring diagram for the kill switch on a 2001 f4i? he told me to just hardwire it and bypass it. that will tell me if its the switch or not. so if anyone has done this please help me out here. i want to tear the roads up tomorrow!
First off is the fuel pump priming when you turn the key? Is there any lights on the cluster?
A wiring diagram can be found in the manual. Here is the link is you don't have one, just click on CBR600. The wiring diagram can be somewhat difficult to read but it is better than spending $60 on the paper manual.
thanks bro! yes, the fuel pump is priming. but according to him the kill switch could just be shutting off the ignition and not the fuel pump if it is starting to go bad and sticking. sound reasonable?
You can eliminate the "rollover kill switch", which I'm guessing he means the bank angle sensor, too. The BAS also wouldn't allow the pump to prime either.
What happens exactly when you it the starter button?
ok, yea i told him if the kill switch was faulty that the pump wouldnt prime. he said not nessisairaly, that if it was just begginging to go bad and not all the way that it could possibly kill the ignition, but not the fuel pump.....i dont know.
yes, new plugs when i put new coils on, no it wasnt missing when i bought it. it ran like a raped ape. and i changed the oil and drove it for 3 hrs and it ran great, then started missing and its just been downhill ever since.....i have been through 2 batteries thinking i had bad ones, i doubt that i bought 3 bad batteries though man.
