F4i fuel pump not priming, FI light stays lit.
Allright, so i have found the cause and the solution to this issue. The cause was all the bodging done to the electricals, the tipover sensor was bypassed, the pink wire was gone and the ecm was flashed to not need the key chip, also a bunch of wires spliced together and some just cut and left to dangle. Rather than just buying a replacement ECM, i bought an ECM, the main cable harness, the HISS antenna, a new ignition switch, tipover sensor. The only electrical piece left from the original bike was the dash. I didn't want to risk what burned out the old ECM, burning out the new one. SO, if this happens to you, replace the ECM and i strongly recommend to search for spliced wires or other ****ty repairs done, or just get a new main wire harness that you know is good.
The following users liked this post:
blackwoodrebel (06-18-2021)
Cmarchandpr
06-19-2013 05:04 PM
