F4i disconnected vacuum hose
Old 01-29-2008, 02:13 PM
danny_l_2005's Avatar
Default F4i disconnected vacuum hose
[align=left]So my friend just bought a 02 F4i and it has been running very rich. Its very sluggish. I told my friend to leave it at my house so I can check it out. So I ran into several problems. One the TPS sensor is cracked, and i found three vacuum hoses disconnected. I connected one already but I can't seem to find where the other two go to. Ill show a picture of these hoses but the vacuums are from the intake side of the head and below the throttle bodies plus its only the outter ports.
[/align][align=center] [/align]
[IMG]local://upfiles/23601/2FDE245FAA674359803AE12D2C2B307E.jpg[/IMG]
[IMG]local://upfiles/23601/34E080C5B47545A08B6D6012ADCC0157.jpg[/IMG]
Old 01-29-2008, 09:15 PM
Default RE: F4i disconnected vacuum hose
If you lift the gas tank and reveal the air filter box, you'll see a diagram for vacuum lines. Connect those and replace the TPS and you should be good to go. Do you have the shop manual for it?? If not, I do and could probably send it to you electronically.
Old 01-29-2008, 09:34 PM
This is what I found in the manual, but like I said, check under the tank. Good Luck
[IMG]local://upfiles/21167/42AC532ED39144888F8BF90F91D04B3F.jpg[/IMG]
Old 01-29-2008, 10:08 PM
Thanks I found where it connected to. On the service manual, it shows that it connects to the air box that has two plastic sticks on the back. Well I changed the spark plugs, and connected the vacuum hoses. TPS sensor still works well. Bike runs great.
[align=left] [/align]
Old 01-30-2008, 08:29 AM
Excellent ... now all you have to do is convince your friend that you're still looking at it and ride the hell out of it for a week or so ... LOL!! Good job man !!
silkyjohhson
07-23-2022 05:42 PM
acurame21
04-16-2012 03:11 PM
uhhmoney
09-22-2010 09:28 AM
Malibuskiboats
11-19-2009 09:32 PM
SuperDave
09-08-2009 09:41 PM
Quick Reply: F4i disconnected vacuum hose
