MAP sensor vacuum hose
Old Sep 19, 2012 | 08:06 PM
silkyjohhson's Avatar
Smile MAP sensor vacuum hose
so the hose that goes to my MAP sensor fell off I reconnected it and followed the other end and it Ts off and both ends go now were and vent to atmosphere. I looked all over to see were it goes but can find nothing. was wondering if somebody knows were it should go thanks
Old Sep 19, 2012 | 08:12 PM
74demon's Avatar
I think after the tee it goes to the throttle bodies 1 and 4.
Old Sep 19, 2012 | 09:43 PM
txsmainevent's Avatar
You are correct my friend.
Old Sep 19, 2012 | 09:46 PM
74demon's Avatar
Whew.... I was going from memory.
Old Sep 20, 2012 | 08:59 AM
Okay we'll I found the throttle bodies but it looks like somebody just ran a hose straight from #1 to #2 and there are two vacuum lines that got from #1 to #2. One is tee off of the fuel pressure regulator and the other is the one I wrote about above which one should it be connected too
Old Sep 20, 2012 | 09:16 AM
74demon's Avatar
The fpr also goes to #1 and #4. (outside throttle bodies)
I looked this morning on a spare motor that I have. The MAP actually Goes to a 5 way tee that goes to each TB. (right ports)
The FPR goes to 1 and 4. (left lower ports)
Upper left ports are for EVAP, if equipped.
There may be a vacuum diagram on the air box, or download a manual.
You could always put up a pic of the hose in question too.
Old Sep 20, 2012 | 10:49 AM
Okay I see the 5 way vacuum couple that one goes to the gas tank and the all 4 throttle bodies. So do I just connect to to that one or the line that goes straight from#1 to #4
Old Sep 20, 2012 | 10:50 AM
There is no diagram on my air box
Old Sep 20, 2012 | 11:02 AM
74demon's Avatar
Whats in the right ports on each TB?
Manifold vacuum wont go to the tank...
Old Sep 20, 2012 | 12:02 PM
I will have to look when I get back home thanks
