F4i disconnected vacuum hose
[align=left]So my friend just bought a 02 F4i and it has been running very rich. Its very sluggish. I told my friend to leave it at my house so I can check it out. So I ran into several problems. One the TPS sensor is cracked, and i found three vacuum hoses disconnected. I connected one already but I can't seem to find where the other two go to. Ill show a picture of these hoses but the vacuums are from the intake side of the head and below the throttle bodies plus its only the outter ports.
[/align][align=center] [/align]
[IMG]local://upfiles/23601/2FDE245FAA674359803AE12D2C2B307E.jpg[/IMG]
[IMG]local://upfiles/23601/34E080C5B47545A08B6D6012ADCC0157.jpg[/IMG]
If you lift the gas tank and reveal the air filter box, you'll see a diagram for vacuum lines. Connect those and replace the TPS and you should be good to go. Do you have the shop manual for it?? If not, I do and could probably send it to you electronically.
Thanks I found where it connected to. On the service manual, it shows that it connects to the air box that has two plastic sticks on the back. Well I changed the spark plugs, and connected the vacuum hoses. TPS sensor still works well. Bike runs great.
[align=left] [/align]
