F4i 600 Valve adjust
Old Jan 4, 2005 | 10:08 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: F4i 600 Valve adjust
Don't try that at home boys and girls [8D]
Old Jan 5, 2005 | 04:44 PM
Miner's Avatar
Indeed! Dont intend to myself! Thought that it was about a 16000 mile jobbie for the CBR600 but I'm quite particular about these things but as I mentioned the valve clearances were within tolerance, esp for the age. But regular oil filter changes are key, skimping saving is th biggest false economy ever. My old Citroen AX had done 130k+ and didnt burn any oil as it was well maintained but the torsion bar rear axle fell apart so the labour costs effectively wrote offf the car! [sm=sigh.gif]
Old Jun 25, 2005 | 04:28 AM
mitch2k5cbr's Avatar
someone said there was a downloadable version of the manual
can antone tell me where that is
Old Jun 21, 2007 | 03:51 PM
JLeosnow's Avatar
ORIGINAL: mitch2k5cbr
Bringing this one back up top.... BTW: does anyone know what the dealership charges(generally) for a valve inspection/adjust on the F4i?
Thanks,
-John
Old Jun 21, 2007 | 04:13 PM
Tahoe SC's Avatar
between 200 to 400 for a clearance check...
to adjust...a couple more...usually you can get it all for $400 though cause they're already in there anyway.
it's not really that hard though.
Old Jun 21, 2007 | 05:50 PM
chornbe's Avatar
Yeah, the biggest thing is time as you hunt for shims. Some dealer will trade them out, others will order them piecemeal, still others make you buy pre-selected packages. It's all messed up.
Old Jul 1, 2012 | 07:37 PM
2wheelfury's Avatar
I know this is an old thread but I am actually about to do this myself. I am really good with mechanics so I definitely think this is a task I can handle. I also just ordered a factory pro shift kit with the spring, detent arm and shift star so that will be getting done as well.
Old Jul 2, 2012 | 09:53 AM
mnguyen84's Avatar
i checked for clearance yesterday. i had to remove the throttle body, and de-bolt the radiator. Removing the valve cover was a bit of a squeeze. i'm gonna make the adjustments today.
I remember there was a thread on this forum that had instructions on how to do it...but i can't find it anymore. The service manual has a thorough walkthrough. If you use the guide for the RR bikes, then you'll have problems @ intake 4.
Old Jul 2, 2012 | 10:05 AM
mnguyen84's Avatar
25,000 miles without an oil change? sounds like BS. at the stage, the oil is not only ineffective at providing protection but it also is building up gunk.
My bike as 35,000+. the clearance for most of the valves are barely off, and most 3/4 of the exhaust valves are still in spec.
Originally Posted by Miner
Saw an article in ride uk which saw a 89 G (jellymould) model which went 25000 miles w/o an oil change and all tolererances were within factory and all shells, journals and cam's were unmarked! A Testiminent to Honda Engineering!
Old Jul 2, 2012 | 03:07 PM
boredandstroked's Avatar
People do it way more often then I'd care to believe. If it was synthetic oil then the oil itself would still be ok although the additives package would be gone. If the person changed the oil filters regularly then sludge build up wouldn't be too bad [although not many people who push oil that far take the time to change filters].
STANJ2
Aug 23, 2011 08:05 PM
WheeliesFUN
How-To: Mechanical
14
Jul 10, 2010 11:54 AM
berga
F2 For Sale / Trade / Wanted
Apr 25, 2010 08:52 AM
96strechedbackF3
Aug 31, 2009 12:05 PM
Cruzinaz
Apr 2, 2009 09:39 AM
