F4i 03 Air Filter
Do you know when/if the previous owner replaced it? Recommended interval is 12,000 miles. I'm lazy and do mine every two years/20,000 miles, same as for coolant and brake fluid.
I got the Bike Master air filter for $30 shipped from Amazon. I saw an increase in fuel efficiency of almost 10%, so I think the old one was a little dirty.
If you use a high-flow one like a K&N, you will probably want to think about a Power Commander to adjust the fuel injection map.
Your best bet is to inspect it before you buy one. I bought a brand new one and when I looked at my current one it was a K&N that just needed a light cleaning :\
Edit: its easy to check them, just lift the tank up and undo all the screws on the airbox. Remember there is a screw right in the middle of the box!
