the f1 light
Old Mar 31, 2009 | 06:39 PM
  #21
letsride's Avatar
If the F1 light is constantly on check your oil level it might be too low.If its flashing and you don't have an O2 sensor then maybe the previous owner replaced the ECU with a california model one and thats possibly the reason it throws that code.
Old Mar 31, 2009 | 07:35 PM
  #22
draudt's Avatar
Question
so basically your saying that nothing is wrong with the bike then? cause it runs fine and everything but the f1 light just keeps throwing me the o2 sensor code. do you think the previous owner maybe took it out because i dont need it here in utah?
Old Mar 31, 2009 | 09:35 PM
  #23
letsride's Avatar
What kind of exhaust do you have?
Old Mar 31, 2009 | 10:05 PM
  #24
draudt's Avatar
its a yoshimara
Old Mar 31, 2009 | 10:19 PM
  #25
letsride's Avatar
If it originally came with an o2 sensor and replaced the the exhaust without an o2 sensor hole,then he might have disconnected the sensor and left it open.I don't recall where the sensor would be but look by the rear shock and see if there is an open plug any where.
Old Mar 31, 2009 | 10:27 PM
  #26
draudt's Avatar
ok cool ill do that tomorrow. IF i find the open plug ill by a sensor and put it on tomorrow. in my repair manual it says somthing about jumping the mil code switch with a wire. Is that just talking about normal jump cables cause i have no idea
Old Mar 31, 2009 | 10:35 PM
  #27
letsride's Avatar
Nah you need a small wire like a 24 guage wire to jump it. As far as the plug if it is missing then I would get the o2 sensor eliminator from dynojet cost is only $15.00 maybe get it at any motorcycle shop.Just plug it in and you are done.
Old Mar 31, 2009 | 10:36 PM
  #28
letsride's Avatar
https://cart.jetkit.com/p-814-sensor...liminator.aspx
this is the plug.
Old Apr 1, 2009 | 12:50 PM
  #29
draudt's Avatar
where does the other end of the o2 sensor plug into? im having troubles locating it. anybody?
Old Apr 5, 2009 | 04:00 PM
  #30
draudt's Avatar
hey guys i think i found the problem. I found this switch that had all the wires cut on it. I took some pics of it to show you guys. Is this the oxygen sensor switch? What do you guys think i should do. put an o2 sensor on the bike or just buy the o2 sensor illiminator?
