Exhaust stud opinions requested
Old May 9, 2013 | 12:51 AM
evesdropper's Avatar
Default Exhaust stud opinions requested
New F4i owner here with a problem. When I got done riding I would notice that I had a very strong exhaust smell on my clothes. The bike started to get louder and tick loudly. Pretty soon the temp was climbing quicker than it should. I figured I should solve this issue. A deeper inspection revealed that both header nuts were missing from cylinder 3. Exhaust was blowing past the pipe and directly onto the radiator any then on up on me.
Easy fix I thought. Ordered the honda nuts and got around to trying to install them today.
Problem: The lower exhaust stud on cylinder 3 is backed out a ways. I am not sure what the best approach to this is. Jam nuts and back it out or screw it in? Snapping it and having to do a more technical work to drill it out and re-tap is my biggest fear.
The stud was backed out far enough I could not get a flange nut on it. So, I pulled all the remaining nuts so I could get a closer look and take this picture.
Any advice is appreciated. Thanks.
Mike
Old May 9, 2013 | 01:51 PM
tqaa48's Avatar
Just throwing out my opinion, I would try and screw it back in, if it came out that far from just vibrations, theres a good chance you'll be able to get it to go back in decently easy. Afterall, its going to have to go back in anyways eventually right? And IF it did break, i think it would break right past the end of the first threaded part and it wouldnt be too hard to get the broken part out since there should at least be a stub. And I know you dont want to tap in out if it came to that, but its really not hard dropping the radiator and you would have straight shot. And like I said, it only makes sense that it should be easy to get it to rethread (but thats in my brain lol).
good luck and keep us updated
Old May 9, 2013 | 02:18 PM
Thanks for the reply. I picked up a couple hex nuts over lunch. I will try it tonight and let you know. I had to order 4 new exhaust gaskets so I threw a couple studs on there also just in case.
Old May 9, 2013 | 02:23 PM
tqaa48's Avatar
Great idea on the extra studs, good luck bud
Old May 9, 2013 | 02:27 PM
tqaa48's Avatar
Oh, and some thread seal tape wouldnt be a bad thoght, could keep that from happening again
Old May 10, 2013 | 12:27 PM
Shocked it with a firm hammer blow before I started and she screwed right back in with almost finger pressure only. Thanks!
Old May 11, 2013 | 10:58 AM
tqaa48's Avatar
Good deal bud. Happy riding
rigbyj05
Mar 14, 2013 09:09 AM
drew_
Mar 12, 2013 11:42 PM
Hollywood
Aug 30, 2009 02:56 PM
MC_spirited
Apr 24, 2009 07:46 PM
TK954RR
May 21, 2008 06:58 PM
