Exhaust stud torque?
Old Apr 23, 2009 | 07:14 PM
MC_spirited's Avatar
Default Exhaust stud torque?
When i took the head off, some of the studs came out of the head. Is there a torque for the studs themselves? Will they torque proper when i put the nuts on them and do the torque for that? Can I just put a couple nuts on the stud and screw it in, install the headers then torque the nut and it will finish snugging up the stud?
Old Apr 23, 2009 | 07:51 PM
02f4irider's Avatar
are the studs and the nut still in the header? and if so you can just theard them back in the head and torque them then. just make sure you dont cross theard them THIS IS IMPOTENT. the torque spec is 9ft lbs
Old Apr 24, 2009 | 06:27 AM
some studs came out, i was just wondering if all the studs had to be torqued before you install the headers then torque down the nuts..
Old Apr 24, 2009 | 07:23 PM
02f4irider's Avatar
just thread them in then torque and your good to go
Old Apr 24, 2009 | 07:46 PM
yeah and some the nuts stayed on the studs. I just got hte head torqued. Just have to put the headers on, reinstall the thermostat. Put in the cams, shims and lifters and everthing else. maybe ill get to ride it this weekend.. hahah..
rigbyj05
Mar 14, 2013 09:09 AM
drew_
Mar 12, 2013 11:42 PM
johncool54
Oct 3, 2012 06:00 PM
LetoCharles
Apr 19, 2012 07:32 PM
nerous
Jul 9, 2009 09:21 PM
