engine temp sensor
well, ive been putting my bike back together since i crashed it. i got pretty much everything back on it except for fairings, i cranked it up today and let it run for a while just to make sure the engine was running fine, and i noticed that the temp got up to around 190 and the fan never kicked on... is this normal? what temp should that thing kick on at? i tested the fan, and it works. my guess is a bad temp sensor, where could i buy one of those from online?
yeah mine comes on around 228-231 and the highest i have seen is 233 i read on another thread(bout a week ago) about replacing the switch with a 87 nissan pulsar switch and then it will come on around 220 and i think you can get a switch that you can turn on and off but will still come on at certain temps im not really too sure i havent messed with mine yet but i will change it somehow
Here is the write-up on changing out the switch:
https://cbrforum.com/forum/how-mechanical-40/f4i-lower-temp-fan-switch-maybe-other-models-105389/
I just got back from my test ride after installing mine and it came on at 205, vs. 228 with the stock switch.
My 01 fan comes on at 220..The highest I have seen was 229 but it was a 115 out and I had been riding for a while and sitting...now I know even 229 is not going to harm anything, but I think 205 for the fan is a bit more ideal..220 seems just Eh...Axsys do you notice that the fan is running quite often now? I assume it is going off almost every time you hit a light! Once I break 200 and up, even if Im cruising, when coming to a stoplight she will creep up to 200-220 real quick. What is your max temp now with the 205 vs your past max?
