engine code
Old Mar 25, 2013 | 01:38 PM
dgk600f4i's Avatar
Default engine code
Just got 8 flashes off of the fi light after using the jumper wire anyone know what that is
Old Mar 25, 2013 | 01:42 PM
74demon's Avatar
Throttle position sensor circuit.
Old Mar 25, 2013 | 03:42 PM
dgk600f4i's Avatar
I changed the sensor what is the circut?
Old Mar 25, 2013 | 03:52 PM
74demon's Avatar
The "circuit" is something in the TP system. Sensor, plug, wire, ecu, linkage, etc.
Old Mar 25, 2013 | 04:43 PM
dgk600f4i's Avatar
Okay thank you. Do you think that would throw off the tempature? I went to see if there was a code because the tempature has been bouncing back and forth up to 15 degrees at a time and eventually overheating.
Old Mar 25, 2013 | 04:45 PM
74demon's Avatar
I doubt it. Probably a separate issue.
Old Mar 26, 2013 | 03:55 PM
dgk600f4i's Avatar
Any ideas on where to start with the temp issue?
Old Mar 26, 2013 | 04:04 PM
74demon's Avatar
Coolant level
Thermostat
Coolant flow
Fan operation
Old Mar 26, 2013 | 10:31 PM
Also, don't forget a bad radiator cap. If it can't maintain pressure, it will overheat.
Old Mar 26, 2013 | 11:07 PM
74demon's Avatar
Yeah, that too!
Dan Jessup
Apr 30, 2014 11:38 AM
mmp1214
Mar 3, 2012 08:24 PM
merkurmike
Jun 23, 2010 05:18 PM
keith5064
Apr 11, 2010 10:54 AM
KRiS
Oct 1, 2006 12:25 AM
