Eliminator Wiring HELP
Old Jul 18, 2005 | 01:25 AM
AcE001's Avatar
Default Eliminator Wiring HELP
Can anyone give me some advice on wiring this up. I tried messing with it today and shot 2 fuses already so guess I am doing something wrong. Here is the link of the elimator http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
There are five wires total
Green (Right Turn)
Red (Stop)
Yellow (Left Turn)
On opposite side of box
Green (Right Stop and Turn)
Yellow (Left Stop and Turn)
Right now I got no blinkers so any help is appreciated
Thanks for the help
Old Jul 18, 2005 | 02:26 AM
AcE001's Avatar
Default RE: Eliminator Wiring HELP
Can someone tell me which wire is positive on the tailight bulbs. The harness has three wires for each bulb. I forogot to mention the bike is an 01 f4i
Old Jul 18, 2005 | 03:06 AM
OutToWin PAHC's Avatar
Hah yeah i had this problems with my hot bodies but i didn't use this kit believe it or not the three wires that are in the back are backwards when dealing with DC remember that it flows from negative to positive. The black wire with the green stripe is the postitive as weird as it is and the two other wires well the one is for the taillight, the other is for the brake. I hope this helps
Old Jul 18, 2005 | 04:44 AM
AcE001's Avatar
What about the 2 green wires that run from each blinker. Where do I wire those
Old Jul 19, 2005 | 01:14 AM
gdharp600's Avatar
An easy way to do this is to go buy a 10.00 test light and test each wire as you do all the signals and brake lights.
Old Jul 21, 2005 | 02:21 PM
looong4's Avatar
I just put one of these on today, i blew fuses but i figured it out. You get it?
Old Jul 27, 2005 | 06:30 PM
Ricepowered01's Avatar
i am in the same boat you are. you are blowing fuse because you have an open cuicit meaning not all your lights are not hooked up. it is because the tail lights are also running lights that is why it trips the fuse. i dont know the colors of the top of my head but i will be redoing mine again this week because my red Fi light is on and wont turn off. so i will take pics on how i am wiring it up. i know you dont wire it with the odd color to power. if you do it before i post the pics. try putting the b/w of light to green stripe. power to green and black to the last one. and if any one knows about the F1 light let me know thanks
Old Jul 28, 2005 | 02:17 AM
mxman87's Avatar
Make sure that all of your inputs are coming from the bike and all of the outputs are going to the bulbs. Make sure to test all of your wires before hooking them up using either a test light or a digital multi meter. To find the correct wires you will look for 12 volts showing only when it is supposed to operate. For instance you will cut the wires going to your taillights and then see which one registers 12 volts when you push the brake. For the turn signals you will need to find the one that goes to 12 volts intermittently when you turn on the turn signal. If you are using a meter it may not make it all the way to 12 volts maybe 9 and then back to zero then back up.... I recently installed a simialr product so if you don't have a way of testing the wires I can tell you the colors tomorrow. Just make sure that you have your inputs and outputs correct and that you didn't get a ground as an input or output. Short circuits cause fuses to pop not open circuits (no current flows through an open circuit whereas with a short i.e. power directly to ground energy can flow unregulated to ground.
mbison83
May 31, 2009 03:19 AM
BlAx19
Mar 28, 2009 10:50 PM
kryptonite_cycle
Jun 9, 2006 11:12 PM
mastice
Nov 26, 2005 04:37 AM
ohg35
Apr 6, 2005 02:29 PM
