ecu f4i 2005 europe
Old Jul 10, 2015 | 10:27 AM
Shay Itach's Avatar
Default ecu f4i 2005 europe
Hello everyone
my cbr was stolen and luckily was found.
unfortunately the thieves destroyed his ecu.
now trying to locate a used part, i was wondering maybe i can use one of the other models ecu.
the serial number of the f4i Europe 2005 is 38770 mdw g71.
i thought trying to use the 2004 ecu which is 38770 mdw d21
or the Australian model 2005 ecu 38770 d41.
please help me get my hurricane on the road
thx
Old Jul 10, 2015 | 06:47 PM
boredandstroked's Avatar
Well, I know the 01-06 ecu's here in america all swap. Should be the same over there although there might be a difference between the normal single seat and split seat "sport" models. Doubtfull but its possible.
Old Jul 11, 2015 | 09:56 AM
sodahyogesh's Avatar
EU Ecu will be a HISS ecu, you would need matched up keys also along with the ECU. post a pic of the ECU here, also what exactly is happening? do the gauges turn over? does the pump prime?
Old Jul 11, 2015 | 11:57 AM
Shay Itach's Avatar
Default 2005 ecu europe
thanks for the answer
the pump doesn't prime...
i know that coding new cheap is necessary.
any how that's not the problem, i can code new cheap.
i also know that the Australian ecu also have hiss system. the question is weather i can use it instead?
Austrlian 2005
WIRE HARNESS - CBR 600 F4 CBR600F5 2005 AUSTRALIA - CBR600F5 - All the Honda OEM parts motocycle from 45000 part list, fast delivery worldwide
european 2005
WIRE HARNESS - CBR 600 F4 CBR600F5 2005 EUROPE - CBR600F5 - All the Honda OEM parts motocycle from 45000 part list, fast delivery worldwide
europe 2004
WIRE HARNESS - CBR 600 F CBR600F4 2004 EUROPE - CBR600F4 - All the Honda OEM parts motocycle from 45000 part list, fast delivery worldwide
Old Jul 12, 2015 | 03:06 AM
Need more info dude. what happens when u turn the key to on and kill switch to on ? does the hiss light come on and go off? does it remain on always? if the wiring correct? is the hiss antenna connected? how do u jump to ecu fault and want to order a new ECU
Bugkiller
The Hurricane Saloon
May 1, 2012 06:37 PM
VIKING LORD
Oct 1, 2009 04:51 AM
rabbit900
Jun 4, 2007 12:57 AM
quans1000blade
Jun 7, 2006 03:53 AM
unsquare
Jan 20, 2006 09:10 PM
