Does a failing CCT cause whole bike vibration?
the sticky does cover just bout all the symptoms, if its not in there then u prolly dont have a cct issue. but if u think about it, a failing cct could cause slack in the cam chain and that could cause some vibration, if u r getting the rattling at 5-6k rpms replace it and see if that helps. if not its prolly something else internal in your enigne causing it if its doing it in nuetral.
sounds like u need to replace it and see if that helps.-and the sticky was made for questions like this
Dang.... never knew what that cct sticky was about until this... my bike vibrates like crazy right around 5k and makes a ton of noise, typically once warmed up.
and this whole time I thought it was valve noise... dang..
wonder if the one from my old f4 motor will work. that one had no noise
doublechester15
05-09-2006 11:34 PM
