-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   Does a failing CCT cause whole bike vibration? (https://cbrforum.com/forum/f4i-main-forum-11/does-failing-cct-cause-whole-bike-vibration-111057/)
i2iSTUDIOS 05-23-2010 02:24 PM
I have a vibration that get's bad from 5k on up but is always there.
Does a failing CCT make the bike vibrate? I've never felt this before. My bike has 13,400 miles on it.
kowen1208 05-23-2010 02:57 PM
Mine doesn't. I just sounds like a tin can full of BBs.
andymp3 05-23-2010 03:00 PM
There is a CCT sticky...Next time please post in there...tks
i2iSTUDIOS 05-23-2010 03:02 PM
My bike vibrates so bad in handlebars, footpegs, everywhere. It vibrates bad sitting in neutral reving, it's terrible, I rode 130 miles today, it was rough.
i2iSTUDIOS 05-23-2010 03:09 PM
My question is a direct one, do you have a answer?
vangill 05-23-2010 03:23 PM
the sticky does cover just bout all the symptoms, if its not in there then u prolly dont have a cct issue. but if u think about it, a failing cct could cause slack in the cam chain and that could cause some vibration, if u r getting the rattling at 5-6k rpms replace it and see if that helps. if not its prolly something else internal in your enigne causing it if its doing it in nuetral.
sounds like u need to replace it and see if that helps.-and the sticky was made for questions like this
mk2mike 05-23-2010 08:06 PM
Dang.... never knew what that cct sticky was about until this... my bike vibrates like crazy right around 5k and makes a ton of noise, typically once warmed up.
and this whole time I thought it was valve noise... dang..
wonder if the one from my old f4 motor will work. that one had no noise
jonld 05-23-2010 10:05 PM
Highly doubt its the cct. I would check the valves and replace the spark plugs.
mk2mike 05-24-2010 12:24 AM
It is weird, on a cold start it is quite as heck... until I literally hit about 5k and then instant noise and then from there on out it is noise until the motor is on a cold start again. sounds nasty too
