Display Problem's!!
Old Mar 24, 2008 | 07:14 PM
Kevin48's Avatar
Default Display Problem's!!
I have a 01 F4i and since I bought it, everytime i turn off the bike, the time resets and trip milage resets. The only thing that stays constant in the actual mileage. When I turn the bike on, it goes through the normal check properly but will always reset the time and trip when i shut it off. I also find strange that the clock resets to 1:00 am?
Any suggestions on why it's doing this?? Loose wire, or not connected? What should I do?
Old Mar 24, 2008 | 07:19 PM
jaynd's Avatar
Default RE: Display Problem's!!
maybe see if your battery connections are loose.
Old Mar 24, 2008 | 07:24 PM
dannutz's Avatar
the bike wouldn't start up ok like it does if the battery connection wasn't good.
check the fusebox. also i remember there was another thread with the exact same problem - maybe someone posted a solution there.
Old Mar 24, 2008 | 07:47 PM
Aken's Avatar
July 2008 ROTM
Sounds like one of the constant power wires is not wired up correctly somewhere. The actual miles stays because it's built in to the gauge itself.
Not really sure what to tell you except try and find a wiring diagram, find any constant power source wires that connect the gauge directly to the battery, and follow them to see if anything looks odd. Could be as simple as two wires stuck in backwards to the plug.
Old Mar 24, 2008 | 08:24 PM
Kevin48's Avatar
I will look into the wiring tomorrow, where does the wiring from the dash go to directly? Also, where is the fuse box on these bikes? Im sorry if these sound like stupid questions but this is my first street bike, i've been on the dirt my whole life. But thank you for your help!!
Old Mar 25, 2008 | 01:00 AM
axsys's Avatar
the wiring from the gauge goes to a little group of connectors by the fairing stay (in between the headlights). the fuse box is located under the driver seat next to the battery.
Old Mar 25, 2008 | 10:17 AM
hoopster3's Avatar
I have the same problem on my bike.I'm notelectronically minded enough to realize what I was looking at when I looked at the wires. If you find a solution please share it.
Old Mar 25, 2008 | 10:52 AM
amnesia's Avatar
I bet you wil find that after all the troubleshooting and messing with the wiring does nothing, that a new battery will fix your problem.
Good luck
Old Mar 27, 2008 | 12:11 AM
Kevin48's Avatar
No, I just put a brand new battery in, its not that. I still haven't got around to pulling the whole display off, but honetly, im not too electronically enabled so I dont really know what Im looking from outside the obviouse disconnected wire. If something was disconnected, would anything on the display work because its only the time and trip meter that dont stay on.
If anyone has had this problem before, please post with the solution. Thanks
Old Mar 27, 2008 | 03:16 AM
FLYOU's Avatar
when you turn off your bike, does the clock disappear completely? because it shouldn't. if it does, then you've got a wire somewhere (in the ignition maybe?) that's disconnecting the console upon shutdown when it shouldn't. could be a pain in the *** to find...
first thing i would do would be to disconnect the console from the harness and check all of the connection pins on both ends. you've probably got some corrosion on a pin somewhere. start off spraying electricial lubricant on both sides of the pin to get the juices flowing better. if you see any rust or corrosion, scrape it off with a sharp tool of some sort.
good luck man! keep us posted. Electrical problems are the worst type to have! I hate em!
eggy9011
May 21, 2009 02:01 AM
rangerscott
Jul 23, 2007 11:56 PM
CaliCbrF4i
Jun 14, 2006 02:40 PM
2k5Silver_Bullet
Jan 25, 2006 11:33 PM
nevian
Aug 25, 2005 03:05 PM
