Dan Moto gp
so i have a mostly stock 06 f4i i do have the tiny carbon fiber dan moto exhaust.. left the o2 sensor in the back zipped off but hanging since there is no premade o2 bung on the dan moto (found out after buying). But i really like the sound from it.. ive read accounts of it being TO loud on other forums but i really like it... it is really not bad when sitting on it at idle just a nice hum.. but a good growl when in the mid to upper rpms.. Anyway its cheap I like it and the FI light isn't on (thought this was weird due to the swinging o2 sensor) So I know the bike has to be running in a default A/F ratio (not good for performance or throttle response.. also so pops and crackles from high rpm dive off.)
l have the power commander III usb on the way,...
anyone have an idea of a map with the stock air filter that would be close to the dan moto airflow????
42 views and no one can give me an idea for a map? I know its not name brand but there has to be some info
Have heard that you can pretty much use a map for another slip on if yours isnt listed, but not tried it as mine has been on the dyno and had a custom map.
And would be worth getting the O2 eliminator rather than having it swinging around or get a nut welded into the pipe for the sensor.
I would ring DynoJet, see if they have any suggestions on maps?
Or run with the stock map for now, you shouldnt do any damage in the short term, and to be honest most people wouldnt even bother fitting a Power Commander for just a slip on.
Or you could just try various maps for 'stock filter with XXXXX slip on' until you find one that feels okay.
Bandit
Nov 17, 2005 11:21 PM
