crushwasher question?
Old Aug 1, 2006 | 02:48 PM
ninetyfivehp's Avatar
Default crushwasher question?
if the oil plug crushwasher is designed to crush at 22ft/lbs, can i reuse my crushwasher repeatedly since i only torqued the drain bolt to 16ft/lbs (which equalled about hand-tight and 1/4 turn with a 3/8" ratchet). don't want any more butchered parts. thanks
Old Aug 1, 2006 | 03:58 PM
christhek's Avatar
Default RE: crushwasher question?
You will see varying opinions on this...but I have never used a new crush washer on any drain-plug and have changed oil on cars and bikes for the past 20 years. Not unless the drain plug itself was replaced. I also have never tourqed any of these items and have never had a leak.
Old Aug 1, 2006 | 04:04 PM
Blackdog F4i's Avatar
On cars I don't worry about torque rating on the drain plug.
On bikes I absolutely do. If that plug ever comes loose you are going down. Next oil change I am drilling it for safety wire. I woudln't worry about the crush washer unless it doesnt seal.
Old Aug 1, 2006 | 04:20 PM
Tahoe SC's Avatar
i torque to spec but i haven't changed my crush washer, and i'm at 40K. dealer gave me this thick washer and said use this...so i have and no leaks to date...i just torque it down to spec...i think if i was to try and crush the washer they gave me, i would have to torque to 1000 ft.-lbs...that thing is solid!
Old Aug 2, 2006 | 12:19 PM
in the sevice manual it says to check the washers condition and reuse if unless its messed up. the owners manual says to change every other oil change. go figure. i figure as long as it seals its still good
Old Aug 2, 2006 | 12:23 PM
also when you buy a new one it has one side that is flat and the other side has a curved edge. anyway, i don't think you need to change it unless you over-torque the plug or scratch the sealing surface.[sm=icon_cheers.gif]
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
