coolant temperature & fluctuation
Old Jul 27, 2009 | 11:47 AM
mxpunk's Avatar
Default coolant temperature & fluctuation
I noticed that when im stuck in traffic my coolant temp shoots in upwards of 200+ degrees, ive never seen it go higher then 220 though. however, once im cruising it will stay between 168-180 depending on the temperature outside..
my question is..isnt such a rapid & drastic change in coolant temperature bad for the engine??
Old Jul 27, 2009 | 12:34 PM
knb13's Avatar
mine does the same thing- these are small engines. They will heat up and cool down rather quick....
Old Jul 27, 2009 | 12:48 PM
mxpunk's Avatar
yeah no doubt, i know my bike is working fine..i just was wondering if such rapid temp swings would potentially cause motor problems (headgaskets popping,etc)
Old Jul 27, 2009 | 01:12 PM
DonF4i's Avatar
No, they are designed to do this, its 100% normal and fine. Mine does the same thing and has 16.5k miles on it.
Old Jul 27, 2009 | 04:46 PM
mike and ikes's Avatar
I'll be at a light after a while out on the road and hear the fan come on. 226 degrees while stopped. The fan will keep it from going higher but it won't go down until I ride at a higher speed. If I'm going around town with a lot of lights the temp will stay up there.
You won't have any problems with temps in that range. If you get into the 240's you may have a problem.
Alexanderfitu
Jan 21, 2014 06:20 AM
davidsnow
Aug 12, 2012 04:03 PM
meanjeans
Apr 18, 2008 01:51 AM
cjp48
Aug 21, 2006 08:24 PM
JC1000RR
Apr 20, 2006 03:08 AM
