Coolant or Oil or No Problem?
Old Dec 4, 2007 | 06:54 PM
QuickNDeadly's Avatar
Default Coolant or Oil or No Problem?
My coolant is low. Can you use standard automotive coolant and do you mix it in some ratio with water? My bike is 2005 Honda CBR 600 F4i. It's 40-50 degrees outside and the tempature went up to 180-190 and when waiting in the traffic (rush hour) it went up to 220. I am asking this since I don't have the manual to my bike. I bought it second hand and they didn't include the manual. Thanks in advance.
Old Dec 4, 2007 | 06:59 PM
travsstuff's Avatar
Default RE: Coolant or Oil or No Problem?
that temp should actually be fine....
Old Dec 4, 2007 | 07:04 PM
Can I use standard coolant or do I need some special mix?
Old Dec 4, 2007 | 07:15 PM
jaynd's Avatar
check you're manual.
i use Honda HP.....something or other, but its a blue bottle of coolant found at the dealer.
Old Dec 4, 2007 | 07:32 PM
Thanx for the advice, but as I mentioned before I would check it if I had it.
So can I use normal coolant?
ORIGINAL: jaynd
Old Dec 5, 2007 | 09:28 AM
fishfryer527's Avatar
There is no such thing a normal coolant anymore. But from the back of the Honda HP coolant bottle it says something to effect of.
Water, Ethylene Glycol, Diethylene Glycol. No Silicates (non abrasive). Meets Astm D-3306. Maximum corrosion protection for all Honda cooling systems.
If you do use something else, let us know what it was and how it worked.
newnut
Jul 31, 2010 12:27 AM
ajohn505
May 7, 2008 07:18 PM
SHugo
Mar 20, 2008 08:19 PM
tj2gq4u
Jul 8, 2007 07:42 PM
BlindLOKI
Mar 8, 2005 11:21 PM
