coolant leak need help
ok i have noticed the past few times after i have quit riding and i go back to my bike a short time after and i have a little bit of coolant on the ground under my bike...i looked up on another thread and ppl say if you have to much in, it will leak out the overflow, my leak is coming from the hose but, the coolant is not full its on the low line but its still comeing out the overflow hose? any suggestions? thank you.
RE: coolant leak need help
I could be wrong on this one, but I believe when the bike starts to cool down it will move fluid around a little bit. I can't remember which way it goes though. I believe that it will put fluid back into the reservoir. If it's over-filled, it will probablys pill a little bit when it does that.
Just go over all your coolant clamps with a wrench to make sure they are all good and snug, don't kill it though...
As for coolent, review your owners manual forwhat isrecomended. I can't remember off the top of my head for sure but I think it's 50/50 mixture of water to antifreeze.
