Coolant hose replacement
Old Mar 27, 2009 | 10:42 PM
MC_spirited's Avatar
Default Coolant hose replacement
I am wondering if i should replace the coolant. I drained it for a flush and for the valve adjustment and some coolant came out of the hoses with some ugly black sort of slimy stuff. Is this the hoses breaking down? Bike has almost 38,000 miles. Im thinking I maybe should just replace the main ones just incase. Anyone had to change their hoses?
Old Mar 28, 2009 | 02:22 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Hopefully it's not your heat exchanger/oil cooler. Was there a lot of it, was it floating on the top? If so, that black slimy stuff could be oil. But it could be also, depending on how long it's gone without a flush, deteriorated coolant and/or contaminants that have collected in it over time. Something to keep an eye on though.
Regarding the hoses, older ones will sometimes exhibit signs of rotting. Meaning they'll become more prone to cracking and oftentimes little chunks will break off when they're bent. Also when they're worn out, they'll develop soft spots, usually at bends. These are easily identifiable by just squeezing along the length of the hose. If there's a spot that's considerably softer than the rest, that's your weak point.
Old Mar 28, 2009 | 06:29 AM
Thanks. The blacks stuff only came out of the hoses after i dumped the majority of the coolant out, which looked a little darkened. But the majority of the black stuff was the "bottom of the barrel" of what came out of the hoses. most of it was the very last of the coolant in the hoses.
Dazed
Jan 9, 2013 08:36 AM
moto_addict
F2 Tech
Aug 15, 2011 12:40 PM
c_o_l_d1
Sep 10, 2010 08:01 PM
c_o_l_d1
Sep 6, 2010 09:39 PM
Sprock
Feb 2, 2010 02:37 PM
