clutch
Old May 18, 2006 | 07:56 PM
jueleus's Avatar
Default clutch
I have never replaced a clutch. FROM 1 to 10 how hard is this gonna be and should i even try i know i need to learn everything about this bike (2002 f4i) my biggest fear is i pop the plate and a millon litttle springs pop out and im lost i have a cbr book coming will that be all i need..................thanks for the help
Old May 19, 2006 | 12:43 AM
G8RCBR's Avatar
Default RE: clutch
Never had to replace a clutch on a bike, but I was just wondering what your attachment had to do with your question....
Old May 19, 2006 | 02:56 PM
jueleus's Avatar
Default RE: clutch
new to the forum just testing stuff road rash
Old May 19, 2006 | 08:26 PM
frostin's Avatar
Default RE: clutch
ya i couldnt say havent had mine off yet but wen we did it on a zr7 was eays id say a 4 or 5
Old May 22, 2006 | 09:06 AM
jueleus's Avatar
Default RE: clutch
thanks for your imput i pulled out the plates they all look pretty worn but i dont know what they should look like bike got ta the point were it would not move even in gear it would not even die any ideas could it be just the plates or is it worse?
Old May 22, 2006 | 11:20 PM
onewheelbandit's Avatar
Default RE: clutch
Getting them out is not too bad. getting them back in is sometimes a pain. I changed mine on my 1000rr in about 30mins. Just follow what you take out when putting them back in. They slide in little groves so I would rate it about 3 1/2
Old May 24, 2006 | 09:07 AM
jueleus's Avatar
Default RE: clutch
thank you very much a should have the new ones on the 25
Old May 30, 2006 | 09:12 AM
jueleus's Avatar
Default RE: clutch
ok well i put the new plates in and nothing i am having the same problem so i spent money on new parts that were not the problem i put the bike in gear and it dose not move the bike will not die in any gear its like its not catching the gear i broke the clutch down a little but i cant get past the center bolt luck nut i guess there is a specal tool for that well i tryed every thing i just cant get it of any help much aperated thanks......................................
Old Jun 20, 2006 | 04:16 AM
nickxf250's Avatar
Default RE: clutch
It sounds as if the gears or the engagement dogs on the gears are worn or broken. I hate to say it but it will probably be a pain to fix. It involves dropping the motor and splitting the cases. I have had to do the job a couple of times and I disliked doing it every time. The nut you are talking about, have you hit it with a impact gun yet. If you try to remove it and it spins you have to hold the basket to keep it from moving. A nice big screwdriver works but I'm sure there is a tool. Sometimes the screwdriver and a long breaker bar works wonders. Good luck.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
