Cleaning air filter w/ removing steering damper
Old Jan 31, 2010 | 02:28 PM
Doughboy63's Avatar
Default Cleaning air filter w/ removing steering damper
So I was gonna try attempt to clean my air filter and before I had even gotten the tools together and I remembered that the ohlins steering damper was bolted where the gas tank cover is that has to come up.
I stopped right there because I didn't wanna touch the damper before asking any of you guys about this.
I never installed it/ adjusted it. It was all done by the previous owner. Would I screw anything up by removing it? Or is all the adjustment in the dial? I feel like such a rookie, but i'd hate to do something and then get on the bike and end up in a ditch lol...
Old Jan 31, 2010 | 07:03 PM
rosscopeeko's Avatar
I have a gpr rotary type damper so my opinion is a little off, but you should have no problem just unbolting it and then replacing it when you're done. It's not under pressure just sitting there, it only acts as a shock when under load. I suggest you should even play with the settings, because you might find one you like better than the previous owner.
Old Jan 31, 2010 | 07:52 PM
Doughboy63's Avatar
I might play with it more when I gain some more experience.. At the moment I've only been on the freeway once and scared myself ****less because I failed to check the tire pressure and was 15psi short in each tire... The bike didn't wanna cooperate and I wasn't really perpared for all this lol..
Since then I've added pressure, and I've done other minor things like lube the chain etc.. But cleaning the filter is all I have left to do. I'll probably work on it next Saturday then, or sometime during the week. Right on for the input!
Old Jan 31, 2010 | 08:35 PM
backroad's Avatar
Only adjustment you'll need to worry about when reinstalling the damper is to slide it in the clamp to a point where your steering goes from left to right, full lock to full lock.
As for cleaning the air filter, if it's a stock filter, it's not cleanable and must be replaced. Aftermarket filters like K&N and BMC can be cleaned and re-oiled with their cleaner and filter oil kit.
Old Jan 31, 2010 | 09:28 PM
Doughboy63's Avatar
word! Right on. I'm only assuming it has a filter being the previous owner did put a pipe and a powercommander. If it has a K&N I plan on cleaning it.
I thought I'd try this before buying a new filter being they run about $60.
haaris954
Feb 21, 2012 04:38 PM
Jaybird180
Jun 17, 2009 04:30 PM
cyber00677
Jun 23, 2008 10:14 PM
clockworkcbr
Dec 20, 2007 03:52 PM
freemanmj
Aug 31, 2007 10:34 PM
