charging problem?? plz help!! :(
Old Feb 4, 2013 | 11:00 PM
jeremymik84's Avatar
Default charging problem?? plz help!! :(
my bike all of a sudden has started dying and losing charge while riding and if i come to a stop and let it get under 3k or hit the brakes or turn the brights on it dies instantly...sometimes it will crank and sometimes it wont.. the battery tested 11.7 volts which i know is not charged but is it the battery causing this or something deeper causing it and causing the battery to lose charge? any help is appreciated... thanks in advance
Old Feb 5, 2013 | 11:27 AM
ttemby's Avatar
it could be a number of things have your charging system checked those might not be working correctly. if it is that order the part and install yourself saves a lot of money. i could be a wire got exposed and is touching metal could drain your battery as well. get the charging system checked soon otherwise you will prolly have to buy a new battery as well. once you find the issue post a reply im interested to see what it is
Old Mar 14, 2013 | 10:09 PM
bump... plz?
Old Mar 14, 2013 | 10:33 PM
mnguyen84's Avatar
check the battery connection and make sure it is tight.
if you're bike is dying on the road, then the problem is more than just the battery. there is a thread somewhere in this forum that talks about how to check the charging system... basically... you start ur bike...get it up to 5k rpm, and check the battery terminals with a mutimeter... if it's normal it should read something like 14+ volts.
but you need to check these 2 things...before going forward
Old Mar 14, 2013 | 10:36 PM
mnguyen84's Avatar
https://cbrforum.com/forum/f4i-main-...-issue-142179/
Old Mar 14, 2013 | 11:09 PM
svek's Avatar
http://www.electrosport.com/media/pd...ng-diagram.pdf
Old Mar 14, 2013 | 11:46 PM
mnguyen84's Avatar
not sure why it recommends that you spray WD40 on electrical stuff. someone did that here on the forum has shorted everything out and had to re-clean it all.
gdjohny
Jan 10, 2014 12:09 PM
mjimenez1
Feb 6, 2010 09:28 AM
blaster
Nov 19, 2007 12:02 PM
jasonp
May 2, 2007 02:44 PM
