Change Hi beam to work as low beam
Just put in some new HID lights and I want to run both at the same time, I don't ride anywhere to run the High's........ Unless I high beam someone, but I figured I would just turn off the high beam switch and turn it on again.......
I know I can adjust the high beam up and down, but what else would I need to do for it to be just like the low beam. I noticed the light housing is slightly different, do I need a different one?
Thanks!!!
Thanks!!!
Did you forget about your other thread?
https://cbrforum.com/forum/f4i-main-forum-11/both-headlights-same-time-103558/
Yeah, just fiddle with the headlight adjustment screws. But it's not recommended.
