chain adjustment
Old Jul 29, 2010 | 02:21 AM
zone01racer's Avatar
Post chain adjustment
so.. i adjusted my chain like 2 days ago. Done about 300 km's so far and the chain already seems to be loose again.
after the adjustment, i also lubed the chain.
the bike was on a swing arm stand/ the front wasn't on a stand.
made sure the 27mm/21mm bolts are nice and tight.
am also sure, i didn't over tight them (although irrelevant).
checked sprockets and looks ok!
chain life is in the middle (middle part of the white block, in between the new/replace area)
any idea why this would have happened?
thanks.
Old Jul 29, 2010 | 03:24 AM
DonnyBrago's Avatar
IME chains coming to the end of their life go from not wearing at all to wearing very quickly. How old is the chain, does it look clean and non rusty etc etc?
If you need to keep adjusting it then it would suggest the chain is dead and should be replaced.
Old Jul 29, 2010 | 05:13 PM
supersnake83's Avatar
Make sure you adjust your chain to the tight spots. Meaning, while your rear wheel is off the ground on the stand, slowly rotate the chain until you get a tight spot. The tight spots are where/what you want to loosen.
Once all of your tight spots are loosened enough to be in normal operating specs, rotate the chain to find the largest slack spot. If your largest slack spot has more than 2 inches of slack either up or down, then it is time to replace your chain regardless of where the chain replacement markers are.
Ideally, the largest slack spot of your chain should be between 1 - 1 3/8" of slack. Anymore and you can have troubles.
Page 3-19 in the service manual will help you if you need to reference it.
Cheers and happy safe riding!
Old Jul 29, 2010 | 06:13 PM
i've had the bike for just about 3 months and done about 10000km's. the chain looks clean and non rusty. i had cleaned/lubed it about 500 km's ago and wanted to adjust prior to the last weekend. hence did so and after about 250-300 km's of riding, i notice the chain is loose.
Old Jul 29, 2010 | 06:14 PM
does chain slack differ from position to position?
Old Jul 30, 2010 | 05:16 AM
Yes.
So does chain tight spots.
Old Jul 30, 2010 | 08:12 AM
mr_pea's Avatar
yep...
you can try to free them up a bit by working some lubricant into those joints and moving them about..
Old Aug 3, 2010 | 09:20 PM
thanks for all the pointers.
now that i am considering replacing my chain, what is the length of the stock chains on the 05 f4i? i realize the sprockets are 16/49 does this indicate the chain length? if so, how do you obtain that?
thanks again.
Old Aug 3, 2010 | 10:49 PM
DBEAU's Avatar
stock is 108 links 525 pitch 16/46
Old Aug 7, 2010 | 07:19 AM
any2wheels's Avatar
Did you say you did 10,000 km in three months?
TheHeggi
Aug 11, 2010 04:58 PM
94fireblade
May 3, 2009 09:40 PM
Perranomous
Apr 19, 2009 03:04 AM
scruboak
Nov 7, 2007 12:19 PM
mmaniaci
Jul 25, 2007 06:50 PM
