Chain adjustment ?
Old Nov 5, 2007 | 05:54 AM
scruboak's Avatar
Default Chain adjustment ?
I am a Newbie here and just got a 02 F4i. The chain seems to have quite a bit of slack in it.What tools will i need to tighten it? Any advice or tips on this task is appreciated.
Old Nov 5, 2007 | 08:27 AM
gixxereater's Avatar
Default RE: Chain adjustment ?
The bike tool kit will have everything you need. Loosen the axle first........then use the bolts and lock nuts to move the rear tire back. Turn each side the same amount. Start small. 1/4 turns. A little goes a long way. Do NOT run it TOO tight. It's better to err on the loose side. A tight chain will bind under a load and put stress on everything.....
Old Nov 5, 2007 | 09:13 AM
Harry's Avatar
Also, your user manual should ahve the whole procesure in there.
Old Nov 5, 2007 | 02:32 PM
white99gt's Avatar
ORIGINAL: scruboak
step by step
http://www.shraz.net/motorcycle/f4i/drivechain/
Old Nov 5, 2007 | 03:34 PM
cbr6oo's Avatar
You said bike tool kit? Does that come on new bikes as a standard or do I need to purchace that sepratly??
Old Nov 5, 2007 | 03:58 PM
white99gt's Avatar
ORIGINAL: cbr6oo
usually standard till 2006 ..If you have one it will be under the seat.But you dont,you can usually pick one up cheap in the classifieds or ebay.
Old Nov 5, 2007 | 04:41 PM
scruboak's Avatar
Thanks for the replies i will check if i have a tool kit. Do i need to have the rear wheel off the ground when i tighten the chain?
Old Nov 5, 2007 | 07:57 PM
white99gt's Avatar
No,but on a stand its way easier.
Old Nov 5, 2007 | 08:55 PM
slip_'s Avatar
Don't even need the bike tool kit or whatever, all you need is a 27, 22, and 8mm socket. use the 27 and 22 to loosen the axle, and use the 8mm to tighten the axle mover/adjuster thingy all the way in, and evenly undo each adjuster until the proper chain slack is reached.
Old Nov 6, 2007 | 08:39 AM
cbr6oo's Avatar
[sm=smiley35.gif]Why did they stop puttin them in!!!! I got a 06'
