THE CCTL Thread
Hello eveyrone,
I THINK i've also developed the "rattle" which would indicate the need to replace my CCTL.
It happens only between 5-6k RPM (not below, not above). I've made a quick video about the sound/rpm range, could anyone just verify if this is indeed the "BB in a can" CCTL rattle before i go spending money on a new one?
Generally speaking, if you look at the RPM in the video, any time the RPM is between 5-6k there's a very distinct rattle (especially at the end of the video where i keep it between the RPM range).
Thank you in advance!
As promised..
The old one came off pretty easily:
-Right fairing off;
-Gas tank lifted;
-Upper bolt from the top;
-Lower bolt from the hole in the frame;
Putting on the new one was a pain however..managed to strip the upper bolt when putting it back in but that's a issue for the future me.
It was the CCTL at the end and my bike sounds a lot better now.
Comparisson video:
-Right fairing off;
-Gas tank lifted;
Comparisson video:
5500, 6000, accelerating, access, adjust, adjustment, ape, bolts, buzzes, buzzing, cam, camchain, cbr, cct, cctl, chain, common, engine, f4i, fix, honda, idle, lifter, manual, mod, noise, pin, ping, problem, problems, rattle, rpm, rpms, sound, spring, support, tension, tensioner, tensioners, tighten, tool
