CCTL install?
Old Aug 10, 2008 | 11:17 PM
Wants a CBR's Avatar
Default CCTL install?
I need some tips on putting it back in. I've been messing with it for an hour already. It doesn't show any signs of wanting to go in. I know that i'm putting it in the right way. Please help!
Thanks!
Okay, so I guess it needs to be retracted. How do I keep it from extracting? There was no key/pin that I hear about. I'm only the second owner of the bike and the previous said that he didn't do anything to it. I believe him since I bought it with 4k miles. I'm lost, am I gonna have to go buy a key/pin to keep the shaft from extracting?
Oh Ya, just to make it clear, I didn't buy a new cctl, just modded the one that came on the bike.
Old Aug 11, 2008 | 12:19 AM
DBEAU's Avatar
Default RE: CCTL install?
us.e a small flat head screwdriver in the top of the CCTL and turn it until it retracts. when the shaft is retracted, hold it in with your hand and take the screwdriver out and insert something to hold it in place as the screwdriver would. i would try to explain better but im hav,ing trouble posting
Old Aug 11, 2008 | 01:08 AM
I don't know what to put in there to keep it from retracting
I may have to make my own tool. A simple tool yes, but it must be the shape of a slim cross. Any ideas?
Old Aug 11, 2008 | 02:09 AM
I'm thinking about rapping it in a zip tie to keep it from retracting.
Old Aug 11, 2008 | 09:07 AM
DBEAU's Avatar
i don't understand how a zip tie is going to work. do you have any thin sheet metal laying around you could cut up? there may be a write up somewhere around here to help with making a tool.
Old Aug 11, 2008 | 10:13 AM
WOT's Avatar
WOT
The retaining pin is a thin piece of metal and I can't imaging how to make one. It's a tight spot, so good luck with a screw driver (which is what the manual recommends). I would highly suggest you spend the $60 for a new one and be done with it.
Old Aug 11, 2008 | 01:08 PM
I know I'm not the only one that has modded their stocker. Where's Tahoe?!? Unless everyone that modded their stocker just bought a new one.
Old Aug 11, 2008 | 10:58 PM
Xuracing's Avatar
there is a lock tool, never messed with it but its supposed to lock it in place when you install it then when you unscrew/ pull it out it releases it. Worst come to worse have it trucked to the Dealer they will install it.
Old Aug 12, 2008 | 09:44 AM
WOT's Avatar
WOT
Although nobody seems to worry about it, the manual warns against even removing the CCTL without retracting it, so I wouldn't go trying to install it in an extended position.
MitchA
Jul 23, 2010 04:51 PM
stryker759a
Aug 7, 2008 03:52 PM
jetjestor
Jul 2, 2008 11:05 PM
aref4i
Apr 25, 2008 05:16 PM
95camaro01f4i
Jul 11, 2006 06:37 PM
