Cbr600 f4i
Old Aug 6, 2017 | 11:11 PM
Captanron's Avatar
Default Cbr600 f4i
Engine sounds like it was full of marbles so i removed it and removed the valve cover. 4 cam bearing surfaces were destroyed on cylinders 3 &4. I figure due to lack of oil. I removed the head and top of pistons look relatively good. Little carbon build-up but not bad. Do you guys think it would be ok with just installing a refurbished head? Thanks
Old Aug 7, 2017 | 09:52 AM
74demon's Avatar
Nope. The bad cam journals will not cause it to sound like it is full of marbles. There is another issue that is causing the noise, and probably the lack of oil to the head.
Old Aug 7, 2017 | 02:18 PM
Captanron's Avatar
I think you are correct. Pulled the pan last night and there is lots of fine metal shavings everywhere. I believe a few rod bearings might be damaged. Seems to have some that are loose between cap and crank. It would prob be best if i just look for another motor at this point.
It was a great running motor for a while.
Old Aug 10, 2017 | 05:08 PM
SunBlue's Avatar
What killed it? how many mi on it? Just curious. I had mine rebuilt awhile ago after failing to find a donor motor.
Old Aug 10, 2017 | 06:08 PM
boredandstroked's Avatar
There is always 4 or 5 on ebay?
Old Aug 10, 2017 | 10:13 PM
Captanron's Avatar
Hey SunBlue. The water pump shaft was broken so prob heat and low on oil. For sure the head is toast. Not sure about the rest of the motor or mileage.
We managed to find the same year bike that was being parted out with a good motor for 150. Not too bad.
Old Aug 11, 2017 | 07:37 PM
SunBlue's Avatar
I bought 2 and both were bad, returned both and I gave up after that lol
damn. My water pump shaft broke couple wks ago too. Glad you got it figured out! That's a great deal.
Old Aug 11, 2017 | 10:53 PM
Captanron's Avatar
We thought it was a great deal untill we found out 2nd gear gone in it. We were think of possibly splitting the cases and swaping out the gear sets. A whole lot of work though. Meantime shifting from 1st to 3rd for a bit.
Old Aug 13, 2017 | 05:50 PM
SunBlue's Avatar
Oh damn. How's it like riding without second gear? u miss it? haha
Let us know how you sort the issue
jpopp88
Nov 14, 2022 12:34 PM
Thor19
Feb 21, 2019 05:16 PM
terranzone
Mar 13, 2014 09:18 PM
Turbulenz
F4i - For-Sale / Trade
Nov 19, 2013 09:17 PM
axnst1
Sep 7, 2010 07:37 AM
