Cbr600 f4i
Engine sounds like it was full of marbles so i removed it and removed the valve cover. 4 cam bearing surfaces were destroyed on cylinders 3 &4. I figure due to lack of oil. I removed the head and top of pistons look relatively good. Little carbon build-up but not bad. Do you guys think it would be ok with just installing a refurbished head? Thanks
Nope. The bad cam journals will not cause it to sound like it is full of marbles. There is another issue that is causing the noise, and probably the lack of oil to the head.
Originally Posted by 74demon
(Post 1306636)
It was a great running motor for a while. |
What killed it? how many mi on it? Just curious. I had mine rebuilt awhile ago after failing to find a donor motor.
Originally Posted by SunBlue
(Post 1306732)
(Post 1306732)
We managed to find the same year bike that was being parted out with a good motor for 150. Not too bad. |
Originally Posted by boredandstroked
(Post 1306733)
There is always 4 or 5 on ebay?
Originally Posted by Captanron
(Post 1306739)
Hey SunBlue. The water pump shaft was broken so prob heat and low on oil. For sure the head is toast. Not sure about the rest of the motor or mileage.
(Post 1306754)
I bought 2 and both were bad, returned both and I gave up after that lol
damn. My water pump shaft broke couple wks ago too. Glad you got it figured out! That's a great deal. |
Oh damn. How's it like riding without second gear? u miss it? haha
Let us know how you sort the issue |
